I'm new to this so please forgive. I have a Volvo Penta AQ125A with a 270 Stern. encountering engine Overheating. Replaced the Impeller as i found it shot, removed all of its debris in the tubes and heat Exchanger and in side the Sea Water Pump. It appears to be pumping Water when just sitting idle at the lake but, over-heats after moving through the water sorta fast. Now i bought the Seals and O-ring for the inlet water part of the Stern's located on the Intermediate section. My question is: Do i need to remove the Upper Gear section and remove the Lower Gear Unit in order to remove the Suspension Fork. I have never done this before and not sure how to approach this. I have mechanical skills as i have repaired my own vehicles (engines) since the late 1970's to now. Could use some guidance on this from who has experience in this subject. Thanks in advance for your help.
