Looking for some help regarding my '97 VP 4.3GS PLKD with a VP SX-C1 outdrive with a belt-driven sea/raw water pump. At the end of last season, I noticed a VERY SLIGHT drip from the pump. A few weeks ago I changed out the impeller for the upcoming season, resealed the pump using the included gasket material and snugged up the 3 brass screws. Re-attached the pump and put it on the muffs to check for leaks. No issues... dry as a bone. Took it to the lake the next day, and it leaked far more than it ever had prior to me touching it. At idle and at WOT, the same leak occurred. Looking at it though, it's coming from the "shaft area" rather than the gasket area. Called it quits for the day, brought it home, put it on the muffs, and no leak! I have a 2-part question if anyone can offer some direction:
- Any reason why it would leak significantly more in the lake, than when under pressure using the muffs? Vibration of the boat maybe?? And while any leak isn't wanted, is there an immediate need to change the pump for a leak like this?
- According to VP's website, the part # I'm trying to find (if someone can check this for me?) is supposed to be a VP# 3851982 superceded by VP# 3857794... However, MarineEngine.com has it crossing to a Sierra #18-3599 which is then a CIRCULATING waterpump... The rep told me I need a #3851623 which is superceded by #3858847? There seems to be some confusion over what part # I actually need.
I know this is alot of stuff to throw at you, but any help would be great guys! I've learned alot from reading what you all post on here... Let me know if I can provide any more info.
Thanks!
Thanks!
