I have a 2000 7.4L MPI Mercruiser, Bravo 1 Sterndrive with an open sea water cooling system. Recently lost the sea water pump impeller. I removed the pump and wanted to flush the intake line while it was apart. Attached a hose and flush ears to the stern drive inlet and attempted flush with engine off. There was absolutely no water flow. I would expect the intake to be wide open with water pouring out of the pump inlet hose. Is there an automatic valve or something that blocks flow while the engine is off? Or is there some kind of blockage?
