3-legged-dog
- So Dec. 2013, i bought a Hardin Marine Sea pump, see link. http://www.hardin-marine.com/p-15774...d-502-mag.aspx
Wednesday night I replaced alternator and starter solenoid. Starter solenoid for ignition issue now fixed and the alternator because housing was severely rusted. and my daughter complained was related to the sound of a bearing going out. whining, intermittently. And because the sea pump and water pump were just replaced in dec. 2013 had to be an alternator. right. either way i have a new one. So Saturday off i go. check the bilge, normal water in the bilge, i always have a little. boom, boat starts right up, first crank. awesome. run a mile to get gassed up. Full tank, ready to hit it for a great day of fishing. always check the bilge after gas. There it is looking right at me. a steady drip from the 2013 Hardin seapump. right out the bottom weep hole. dripping hard and steady with engine off. i run back to the dock, close the sea cock.
question, now the untimely repair with the boat one hour away and floating in the water. i need to bring the right tools down. On the Hardin Sea pump do you think i need to pull the entire pump out and disconnect the hoses off the back housing or just pull the front cover off. i dont remember if the 5 front housing bolts attach from the pulley side of the rear. Also to pull the pulley and repack the front head with new ball bearings etc. can that be done on a tailgate of a truck or do i need a press or something?
also, a little early on a sea pump repair i think. my last merc. pump lasted 10 years. Thoughts?
John
