screwed up. need help!!!!!!! 85 hp evinrude
1969 evinrude 85 hp. wasnt getting fire to plugs so took off flywheel to clean up and see whats wrong. in the process i tore off a plug wire from the distributor cap assembly. anyway to reconnect? im new to boats so im afraid ill have to buy a new one.
Pulled on the wire, didn't you? You aren't the first and won't be the last. The wires have threaded terminals on the end which unscrew from the cap. You probably will have to get in the tower with some sort of tool (screwdriver??) to unscrew and remove the terminal. Then buy a new wire here at marineengine.
Fanfrickintastic. Getting frustrated.
(Replacing Screw In Type Plug Wires)
(J. Reeves)
It's next to impossible to find replacement spark plug wires for the older engines that have the brass screw in terminals which screw into a distributor cap. The solution to correcting a spark plug wire (or a coil wire in some cases) of this type is as follows:
Purchase however many brass screw in terminals as you may require (OMC Part #510364). Price is about $1.75ea. If you also need the spark plug boots and the spring terminals that connect to the spark plugs, purchase them also (OMC Part #581027). This includes one boot and one spring connector. Price is about $3.25ea.
Purchase whatever amount of spark plug wire you need. Be sure to purchase the kind that has a steel twisted wire leading through the center of it....... not the carbon type plug wire that many automobiles now use.
Have a piece of 2"x4" handy or any other piece of wood that will suffice, and if you have a vise, clamp that piece of wood in it. Punch or drill whatever amount of holes you want in the top portion of the wood...... you want a almost perfect size hole that you can easily screw one of the brass screw in terminals into. I normally use just one hole, reusing it as many times as necessary. The terminal should screw or push in easily so that removal is just as easily...... but you do want the terminal to be held securely.
Using your old plug wire, cut the new wire to a length about one inch longer. If you have no old plug wire, just make sure that the wire is longer than you'll need as you can trim the other end later. The end that the brass screw in terminal will go on... cut the insulation back about 1/4". With your finger, seperate the wire strands so that they are seperated and angled off at about a 45° angle when viewing the wire being held straight up. Tint those wires with electrical solder, then fold them down against the wires insulation, cutting the excess of so that the wire ends do not extend past the circumference of the wires insulation, meaning..... holding the wire dead on, those tinted wires form a circle.
NOTE: Electrical solder is 60% Tin and 40% lead with a Rosin Flux Core, available just about anywhere.
Before doing any solder work on the brass terminal, check to make sure that the wire you've just prepared will slide into the brass terminal withough being forced.
With a hand held propane torch with a pencil tip, heat the brass terminal just hot enough to fill it with "Electrical Solder". Do not use any other type solder. Do not overheat the terminal. When the solder is a liquid, filling the brass cup, having the prepared spark plug wire handy, insert the prepared wire end into the melted solder within the terminal..... and hold it there for a few seconds to have the connection secure. That should take care of the screw in brass terminal end. Use "Caution" as that melted solder could spit out somewhat as the wire is shoved into the brass terminal.
The above procedure also holds true for the engines that have "Battery Capacitance Discharge" ignition, which is a fancy name for a battery operated powerpack.... quite a few engines in the 1968 to 1972 range. That would be the type that has one coil whereas the coil wire screws into a distributor cap located under the flywheel.
The rubber boot, spark plug end.... With the wire cut to the length required, trim back 1/4" insulation again but do not solder tint the wires. Simply fan out the wires and fold them back against the insulation, cutting the excess off as explained above. Holding the spring wire terminal, estimate where the prong should be inserted so that the spring will be flush against the exposed wire. Hold the spring terminal away from the wires end (sideways) and insert the prong into the insulation and into the center wire, then swing the spring terminal in front of the exposed wire portion (makes a tight fit for continuity purposes).
Spraying the inner portion of the boot where the wire will insert with a small amount of WD40 makes the installation of the wire a easy project. That's it.... you're done.
Many thanks to Joe for all that information. But just so you know, the complete wire assemblies are available here at marineengine.
580761---#1
580763---#3
580762---#2&4
$24.00 each. Your choice. Joe's way of course is much cheaper, if you have a torch, solder, etc.
FDGator..... I wasn't aware of that. As old as those ignition systems are, I felt sure that those wire assemblies were a lost cause as far as a purchase was concerned. I'll try to remember to make a entry in my database to mention their availability here on MarineEngine.com .
