bill_w
Advanced Contributor
Continuing on my partial teardown of an 89 115 Johnson. I had a leaking head gasket, that was letting the combustion gasses into the cooling water, that totally screwed up both thermostats, and melted the plastic reflief valves. It also looks like it caused scoring of the piston skirt, that is visible thru the exhaust ports. Can I run the motor like this, or am I looking at a total meltdown? The rings and area of the piston above the rings are good, and the cylinder above the exhaust ports is good. Only the one piston is affected.
I'd like to get at least this season out of the motor, without having to do a complete teardown and re-bore. Any thoughts on being able to run it as is?
thanks,
Bill
thanks,
Bill
