"Earlier I posted a question r
"Earlier I posted a question regarding water temperture V6 merc.
I was having a slighte over heating issue after long runs. After coming to a idle engine would heat up, or after running hard.
New impeller was installed , still same issue. Pulled the thermostat and found it to be very crusty with scale...Replaced it, and pulled the water lines coming into and out of the Thermostat housing.. The housing was plugged with scale like crazy, water flow was down by 50% was shocking...reduced to a finger hole of in and out water channel.
So now going to replace the Thermostat housing and pull the water pump to inspect it for blockage.
The port water line going to the riser was so much hotter than the starboard one from the stat housing.
Has any one come across a good winter stablizer that prevents scaling and is not a enviormental issue.
I am hoping that the housing replacement will solve my temp issue. A acid bath in the fall before storage was suggested to clean the engine up from scale.
Thoughts comments....?
Regards
Christopher"
Regards
Christopher"
