Motor is a 1995 Force 90 Hp. Serial OE104323.
Problem: motor runs for 15-20 seconds and dies as though something was jammed into it. When it dies it sneezes and it appears to blow white smoke from below the flywheel.
there is a lot of oil film on the underside of flywheel and down the side of the block on the electrical side. I am suspecting the top crank seal is bad. Any thoughts?
Also the water pump was just rebuilt completely and the water stream is a little more than a dribble. When I removed the old pump parts I found the sleeve inside the coupler with the water tube to be missing nearly half of the sleeve. I am thinking it is inside the block somewhere. Any thoughts on this?
Thanks again in advance for any and all help.
rcb13
rcb13
