Hi folks, first time here.
a friends sailpro 6h fell off her transom mount a couple days ago. It wasn't running at the time. I took it home to get it going again. Now I'm getting nothing but a very occasional backfire.
What I've done:
inspected motor housing when I got to the boat -within an hour of submerging. No evidence of water inside the cover anywhere. Easy pull on the starter had no excessive resistance.
Took it home to work on it and did/found the following:
changed oil twice ( it was milky)
replaced plug,
checked fuel pump -working
inspected carburetor -working and clean. Float works, jet unobstructed, no evidence of water.
verified spark with plug out of block, sparking as expected, but can it be insufficient?
checked by hand draw through carb, and suction/compression in cylinder at plug port.
Only took lifter cover off,
all seems to be OK otherwise, but am wondering about timing, or other things to check
suggestions appreciated.
Jeff
What I've done:
replaced plug,
Jeff
