knuckle47
Advanced Contributor
"I am having to do a top end j
"I am having to do a top end job on the port 454 engine and I have it ALMOST fully disassembled. Here is my dilema...I had to cut the heads off of 5 of the 8 bolts that secure the manifold to the head. This means there are 2 long "studs" and 3 short ones STILL holding the manifold onto the head. It seems like the 2 inches of long stud passing thru the hole of the manifold and into the head are SO CORRODED they have "rust welded" the thing together. Without removing the manifold I cant remove the head or valve cover. I have SOAKED and SOAKED the area with penetrating oil BUT I believe I may need more drastic measures. Anyone venture a plan like drilling the studs out or cutting the tabs on the manifold....I sure hope there might be an easier way....
