Mulletwagon
Thought I would change the distributor caps and rotors onthe old 454XLs – should be easy me thinks ! Stopped cold at square one when I discovered all four distro cap screwsare rusted solid. Asked around for theschool solution and got several recommendations.
Has anybody used any of these techniques and did it work? Other recommendations welcomed.
Thanx,
FL Panhandle
- Apply penetrating oil for a few days and back the screws out with light bumps from an impact wrench.
- Break off the distro cap to provide full access to the screws and apply heat from the blue tip wrench.
- Remove the distro assembly from the block and give it to a machinist.
- A combination of all the above (before or after shearing the screws).
Thanx,
FL Panhandle
