rust in ujoint bellows 1977 120
77galaxy
77 merc 120 hp 2.5.
Removed the drive and found rust in the ujoint bellows.
Bellow looks good no cracks and was sealed good on each end.
Where could the water be coming from? :confused:
Re: rust in ujoint bellows
Appears gimble bearing is ok. Feels smooth. What seals, if anything from engine to transom? My guess is the water level got high inside the bilge
None, directly above the bearing is a hole and with the bearing removed is another hole at 6:00 .
That explains where the light was coming from. I could see sunlight coming in from behind the gimble bearing after I removed the bellhousing
