Background:
i have restored a 1982 wellcraft bowrider 180 that has the mercruiser 140 engine, 3.0L 4cyl 181.
When I finished all of the interior restore I drained the tank because it had been sitting for 5 years, drained all of the fluids and refilled everything. I took the carb in and had it rebuilt and a tune-up. When I took the boat out it ran great for about an hour and in the middle of a run it bogged down and would not get above 1500 rpm even at WOT. I have just taken the boat to a mechanic and he tested the pressures which were really low, 110-85-55-90 and suggested that the engine be rebuilt.
problem:
I pulled the head off of the boat to have it pressure tested and found rust in the intake on the head, that seems weird to me but I have never worked on a boat engine and not sure if this is normal.
Also, when i removed the valve cover I found that all of the lifters had a thick milkshake like goo on them which typically means water is mixing with oil. The water i drained from the block was all nice and clear, dont know if that means anything.
Should I go ahead and pull the engine and have the block pressure tested and what else should I be checking?
problem:
