Runs fine in the back yard
poncho52378
I just got back from the river
I just got back from the river and had no fun! I just rebuilt the carb.and this is the first time been in the boat. bought it from a guy I work with. It runs fine at home but when Put in the river today started fine as i gave it some throtle it died?? I may have panic the current was swift today so I put it back on the trailer and came home. Maybe I didnt let it warm up???? any help or ideas would be great. Its a 1987 25hp merc.
"lets get a timing light, put
"lets get a timing light, put it on each plug wire while running in the yard, check for spark on both cyl's. They all sound good on the hose. Did you adjust the idle mixture after the carb job.
Quote Check your manual for the proper initial setting.
Most times its between 3/4-1.5 turns.
IF engine is running lean.
With the engine IN water and IN gear.
Turn the set screw counter clockwise until the engine starts to load up and slow down.
Once it loads up, start to turn it back clockwise until the engine starts to clean up and runs faster.
IF engine is running rich.
With engine IN water and IN gear.
Turn the set crew clockwise until the engine starts to stumble/pop and slow down.
Once this happens, start to turn it back counterclockwise until the engine starts to clean up and runs faster. <---TIP.....once you find this position, open the jet 1/8 of a turn futher and try it. If it stumbles on take off, return it to 1/8 of a turn back.
The Marine Doctor
from another site"
