Running Problems johnson 150
B
bradboat
Guest
"Johnson 150 '96
Engine
"Johnson 150 '96
Engine runs fine at top speed and idle but when throttle is engaged the motor begins to vibrate and sputter. By increasing speed, the engine seems to finally get enough fuel and runs fine.
Carbs maybe?"
Yes Brand new!
Ran it yesterd
Yes Brand new!
Ran it yesterday wide open for a while and worked fine. I slowed down and it still worked fine. But after shuting it down and letting it sit for a while the same problem occured at low speed.
"do the basics,...ck spark,...
"do the basics,...ck spark,...ck compression,check for water in fuel,..ck linkage and synchronization,..all good,....clean/rebuild carbs using NEW parts...every orifice in carbs MUST be absolutely clean,for it to work correctly."
"Try hitting the choke button,
"Try hitting the choke button, then drop the hammer and see if helps the problem.Let me know what happens."
Nothing changed after pushing
Nothing changed after pushing the choke.
Motor is starting to stall when throttle is engaged slowly. i have got it to run by slammin the throttle down right after turning the key....and again it rus great at higher speeds.
"heat soak......
to correct t
"heat soak......
to correct this,...make sure throttle roller on spark advance,is touching cam,at idle position..
all omc eng's needed spark advance before throttle,...those eng need throttle and ign at same time."
"have a johnson 112 spl, with
"have a johnson 112 spl, with throttle all the way down, it runs at 4 rpm's & does not plain out.
very slow, also seems to use a lot of fuel, any ideas?"
