troym
Advanced Contributor
Was curious about the basis behind the precaution of not running the engine at >1500rpm when using the garden hose and muffs for cooling.
The only thing I've found in the books is that the suction of the outdrive water pump (impeller) at higher rpms could collapse the garden hose, restricting the water supply.
I usually use my well pump when I run the engine in the driveway. The well delivers 50-60psi and 25gpm at the discharge. I've never seen any indication of the hose collapsing. I don't make it a habit of running the engine at more than idle speed, but have revved it a bit from time to time.
Even at higher rpms, there has been sufficient flow to force water out around the muffs and supply the engine, as indicated by water issuing from the idle ports and out through the prop hub, and normal running temps.
Just wondering if there are any other concerns.
