I have a 2003 Johnson 2 stroke running one one cylinder. I have replaced spark plugs and checked spark with a spark tester set at 7/16" gap. It jumps that gap easily. Both carbs have been rebuilt and are good. Removed reed valve assy. and found no problem. VRO checks out. Even if I squirt fuel in the cyl. that isn't working it makes no difference. Swapped carbs from top cyl. to bottom cyl. Didn't make any difference. Checked pulse limiter and it seems to be working properly. I pulled cyl. head to check piston and cylinders even though I had 140 psi on each cylinder. Everything looked good.Tried to put pressure on crankcase thru pulse limiter but I couldn't build up any pressure. According to manual it should pump up to 15 psi. I checked upper crankshaft seal and it was good. Is my only option is to pull power head and check lower crankshaft seal?
