I have a new to me boat with twin crusader 8.1's. Starboard engine is running hot. Changed the risers, oil cooler, impeller in water pump and had heat exchanger cleaned. Riser is still very hot hot and engine temp climbs over 190 and then I back it down to keep temp from hitting 200. I ordered an new raw water pump just to eliminate it as a possible issue. The engines are 2002. Is ti possible the hoses can be collapsing like fuel lines and restricting water flow at higher RPM's? I pulled the hoses from the heat exchanger to the risers to see if there is water flow and there is good water flow at idle? Any suggestions?
