fishingpapa
Need some help, please! 79 Johnson 175 HP. Pulled the top and bottom carbs to replace all fuel lines. New carb to manifold gaskets installed. Didn't do anything to carbs. Linkage is free, and appears to be correct. Throttle cam is not touching linkage. Throttle butterflies closed fully. Carbs synced. cannot find any air leaks at base of carbs. Advance is bottomed out. Motor was idling fine, on muffs, five minutes before I pulled the carbs. Motor is now idling at about 1700-2200 rpm on muffs. Could it be a stuck float, something else? Any ideas? Thank you!
