Need some insight on rudder removal, I have all the obvious bolts out but rudder still won't budge. don't want to apply too much force just yet till I'm sure that I haven't overlooked something.
application is a midsize twin engine sportfish......has a robust rudder and housing then post goes through a rudder shelf that has a bearing housing with a grease fitting and 4 bolts into the shelf. above that there is a collar with a bolt that retains the rudder post then an arm that connects to the rudder tie bar.
all obvious bolts are removed and the packing nut is backed off????
won't budge.
Tony G.
won't budge.
Tony G.
