cluelessformula
Throttles uneven and not running the same on both engines. Butterfly opening at the same time so it isn't the controls. When the port is at the wall at 4000 rpm, the starboard control is only half way up. 496 mag ho on both sides. Replaced the plugs, wires, checked the TPS, pulled and had the injectors profesionally cleaned, checked fuel rails and pressure. There's no real shake in the engine and you can't tell there's any kind of miss, but I'm losing power and rpms. Anyone have any suggestions??
