pugetsounder
Advanced Contributor
1982 19' cuddy MCM 470
As some of you might remember I replaced my upper this past winter with a different one thinking that my current upper had the wrong gear ratio (1:1.98). The stock came with a 1:1.84. My rpm range is 3800 - 4200 but I can reach way higher rpm than that. And cruising in that rpm range my top speed is only 28 mph. I know the boat should go way faster than that and it does but at dangerously high rpms. I took the boat out yesterday for the first time since the new upper ratio and there is no difference! I expected a higher top speed. And I can throttle up to 5000 if I choose to.
My props are 3 blade alum MCM oem 14" 21P and a 4 blade SS 14" 21P and I get no difference between the two. I noticed in my 470 installation manual that some 470s came with a 1:1.65 ratio drive. But I don't know if this boat came with that one or not. the 1.84 seems pretty standard. And the prop is standard as well. I know with the proper ratios and prop I should be at about 40+ mph at 4200 rpms on this particular boat. I am stumped at this point. Any advice is appreciated.
