On my 1970 60HP ESL 70D, I have tried numerous approaches to solve my RPM's from fluctuating at idle speed. I rebuilt carbs, new floats, adjusted correctly, new needle valves, new fuel pump and timed and set points. On a cold start, the choke works correctly, it will idle smooth only after a few laps around the lake. I will put back in neutral and the RPM's seem to fluctuate. Sometimes between 100 RPM's to 50 RPM's. Watching the tack you can see the needle bouncing up and down. At take off there is a slight stumble and after 2,000 RPM's the high fuel circuit seems to work fine -- no stumbles no misses -- holds steady at RPM's of 5,000 smoothly. When I drop down to neutral then the problem occurs. Again it seems to be after the motor has warmed up.
At home on the muffs it holds steady at 10,000 RPM's smoothly. I am kind of at a loss as to where to go with this issue. Although after a long time trying to get my carbs set correctly at slow speed idle adjustment, and learning from this site to get these carbs tuned correctly, sometimes you have to run them on the rich side as I have done, altering a smooth idle. But is the sacrifice of me willing to accept this RPM fluctuation? Or is there something I am missing.
Thank you,
Tony
Thank you,
Tony
