Ok...I'll admit, I've had a few hang-nail type items plague me this year. First, worn out plug wires were leading to an engine miss. Fixed and ran perfect. Then a faulty oil pressure shut off switch was intermittently cutting off power to my fuel pump. Fixed and ran perfect.
Now I believe I'm battling water in my fuel. Boat ran great for several outings and many hours. Then, this past weekend out trolling noticed a rough idle, but not too bad. Later coming into the harbor it would barely hold an idle. It was all I could do to get her into her slip.
Went down today, replaced the fuel/water separating filter, poured some sea foam into the tank. Started her up and she purred like a kitten. Took her out for a spin and ran great. Brought her back into the harbor and she began to run rough again but not as bad as the other day.
Concerned my carb is gummed up, but hoping it does not need to be rebuilt. Do I keep replacing the water separator until it passes?
Spoke to the mechanic and he said fuel/ethanol/water problems are the #1 cause of repairs this year, with at least 12 other boats in the marina with similar issues.
Thoughts or other suggestions? Thank you.
Crusader 454XL Holley Carb
