"At full throttle you should b
"At full throttle you should be burning about 10-12 gallons per hour - that is NORMAL.
These are gas pigs just like every other outboard out there.
The rough idle could be due to, varnish/clog forming on the low speed carb jet, old plugs, carbs out of adjustment (although they almost never go out on their own), old gas (gas that's 2 weeks old is OLD).
Only way to improve fuel economy is get a smaller motor. For all the advances that have been made an 1970/80 something 115 burns 10-12 gallons per hour. A new 4 stroke 115 burns 10-12 gallons per hour ditto Merc's Opti's and Evinrudes ETEC's.
Stay light on the throttle, consumption drops by over 50% if you use no more than about 3/4 throttle - every motor has a sweet spot usually somewhere between about 3200-4500 rpms (depending on the motor) - you just have to find it..."
