2002 Mercruiser 5.0 Litre V8, Alpha drive, Thunderbolt V ignition, 2 bbl carb, fresh-water-cooled with heatx
1. Repaired no-spark condition by replacing corroded distributor ignition sensor module. Had to drill out seized distributor cap screws to get cap off & then drill/tap them to repair distributor.
2 Now engine runs:
Starts OK, rough/erratic idle hot & cold (choke working OK)... sometimes nearly dies, other times runs OK for 30 seconds
Tried 2 different good timing lights. Both are intermittent (sometimes no flash on #1 cylinder) and marks jump around - did manage to set timing at marks [10 degrees BTDC] (jumper lead used to lock timing at full retard)
New spark plugs come out cold/dry fouled with black soot after about 1 hour total running in neutral trouble-shooting problem (Mercruiser manual says that's a sign of weak ignition)
Carb removed and disassembled - very clean, no water or dirt, float level checked OK
Replaced fuel filter - no water or dirt in old filter
Filled fuel tank with new marine gasoline
Flame arrester clean - engne runs the same when on or off
PCV valve clean & not stuck open
Changed oil & oil filter (Sierra marine 25-40 semi-synthetic) - old oil was clear & looked OK
Compression checked - 190 to 200 psi all 8 cylinders
Tachometer and alarm horn working
Battery tests OK & cranks engine quickly
Alternator charging
Engine temperature normal (160 F) & risers not hot (100 F). Heatx full of coolant & no leaks.
Engine wiring harness plugs and terminals shiny & clean (except at 35 amp circuit breaker near carb, which was replaced)
Spark plugs: old ones replaced had light brown insulators and shiny black noses all 8 cylinders - OK
Replaced distributor ignition sensor, rotor, cap, HT leads (spark plug wires), ignition coil, spark plugs, ECU (electronic control unit/module)
Distributor shaft not worn & rotor not wobbling
Inside of cap dry & clean
HT leads (spark plug wires) run in wire guides & crossed as little as possible
Replaced main engine 35 amp circuit breaker near carb (corroded terminal)
Cleaned/tightened all battery terminals and cable lugs including on battery main switch & starter solenoid & engine block ground stud
Carb accelerator pump spraying fuel when throttle lever moved forward
Engine will rev to over 3,000 rpm (wants to go higher) in neutral without missing or backfiring
Thinking worn timing chain, low voltage/voltage drop/bad connection in engine harness wiring, ?
How do you get the plastic guard off the carb mixture screw so you can adjust the idle mixture?
2 Now engine runs:
Alternator charging
