Hello everybody.
I have a problem with my Volvo Penta DP-SM outdrive and would be really happy with some help from you guys as I have ordered a crane for launching the boat on Tuesday.
I had som water in the oil and did a pressure test. This showed that I had a leak in the outer prop shaft seal.
I took it to the local marina to get the nut that holds the bearing carrier. I then changed the seals and o-rings.
After that I brought it back to the marina so they could tighten the nut.
The mechanic said that he had set the rolling torque to 2,5nm (1,8lb-ft).
When I got it back I tested the rolling torque by winding a thread on the input shaft and attaching a fish scale. With some calculation I only get 1nm (0,7lb-ft).
Now I’m contemplating what to do.
I can ad that before taking the unit apart I also had rolling torque of 1nm.
Also I made a mark at 12 a clock on the bearing carrier nut and after mechanic has tighten it the mark is between 1 and 2 a clock.
- Have the mechanic made an error and I should bring it back and retighten it
- Have the mechanic set it to 2,5nm but after some spinning when I was measuring, the bearings has “settled” and the measurement has changed and I should retighten it.
- This is normal and I should just launch the boat
