"Rod,
A couple of weeks ago y
"Rod,
A couple of weeks ago you posted something about how you wired your Alpha shift interrupt switchs on your 6.2's.
If I'm not mistaken, you said that you wired it so that it opened the pink/white coil trigger circuit that goes from the coil to the ECM.
The wiring diagram I have shows that the pink/white wire is actually the power for both the coil and coil driver and goes to splice 108 in the wire harness, not the ECM. It shows the coil trigger circuit being white/light green and going from the coil to the coil driver.
Can you clarify for me please.
Thanks,
Dave"
"Rod,
Thanks,
Dave"
