"I put a Rochester 4bbl on my
"I put a Rochester 4bbl on my 1986 170 Four Winns 4.3. omc. It is a factory rebuilt marine 4bbl that was listed for a 4.3 mercrusier. Four Winns offered it as an option in 1986.It does do what I want- it gives me more power at hole shot with a full boat and pulling a skier. It allows me to do the same at a 5000' altitude lake we visit (which I couldn't do before).Problem is- engine runs great at WOT 3800-4000, it runs great at lower end of rpm. It starts to stumble at 2900 to 3400. It acts like it is getting too much fuel. I have looked into the carb while this is happening (with my wife driving boat) and the secondaries are just starting to open at this point. I have adjusted the air valve spring on the secondaries from tight to loose and at sea level it doesn't seam to make a difference. (At 5000' the air valve has to be set loose to run correctly maybe thinner air?) I was wondering if changing the metering rods in the secondaries would help smooth out engine at that rpm? Any suggestions welcome, Thanks"
