Rochester 2 Jet Carb - cleanup and help
ready2go
Hi - I'm new to this board, and i think I have my question in the right forum section now !
I have a Rochester 2 Jet Carb (120 Mercruiser i/o, Starcraft 18' aluminium bowrider). I had problems this summer with the engine faltering after going to full throttle, even advancing the throttle there very gradually. If I stayed at half throttle I was mostly OK, as long as I didn't try to go to the top. Then it would stumble and if it didn't stall, it would go back to a pretty slow state until I idled for a bit and tried again.
So I took it apart, and with a couple visits to my marine mechanic and some online stuff, learned about the jets, power valve, accelerator pump, etc. I'm new at working on carbs. I can make the springs and valves for the power system move nicely. The problem I'm having is the little ball bearing under the acc pump springs, which fits into that little hole there. It is stuck in the hole and isn't coming out so far. The question I have is twofold:
1) How can I loosen that ball out? I tried carb cleaner and it didn't do much. I thought about using heat but I was reluctant to go to that option yet.
2) Do I really need to get it out. I haven't had it back together to test yet. I read in the older posts on this forum somebody thought that "there were a lots of carbs out there with the ball stuck in the hole, and the operator hasn't noticed". If I just put it back together as is, would I notice there was a problem?
I assume that my power problems were more related to the power pump or other filters, and not the accelerator pump.
Any insights are much appreciated. I like what I see in this forum and look forward to being a part of it!
The ball serves two purposes, it allows fuel to be pulled into the pump chamber, and when the pump is compressed the ball stops the fuel from going out of the inlet but instead to the outlet to the nozzles.
