"Twin 1988 454 Crusders FWC. Y
"Twin 1988 454 Crusders FWC. Yesterday when doing a scan with infared temp gun noticed the port riser/elbow and exhaust hose behind it, on starboard engine was very hot. Temp at idle was 180+ on the riser/elbow and 210+ degrees on exhaust hose. Temps were taken at dock at idle after about a 20 minute run to make sure everything looked OK after changing coolant. If increase RPM the temp goes down quickly to 170-180. Note the main engine temp is fine at 150-160, it is just the temp I am getting on the laser gun at this elbow/riser. Also risers and elbows are new last year. Impeller is new and seems to be pumping good water, the starboard side riser and elbow of this engine are at about 130-150.
Pulled RW supply hose to the riser and getting good flow. Thinking must be a blockage somehow in the riser or elbow channels?? They are only 1 year old though. Guess I should pull and check out.
Any other suggestions?? Thanks
RM"
RM"
