Ring stuck
spicerak
"89 evinrude xp 150 my boat gu
"89 evinrude xp 150 my boat guy took engine apart and said there was a ring stuck,what would cause that and what will it make a enging run like thanks"
Piston rings are a key compone
Piston rings are a key component of engine operation.It affects compression and also keeps combustion gasses fron getting into the crankcase.Lousy oil / overheating / scoring of piston and poor quality gasoline will cause a ring to stick.Simple really.
I suggest you take the advice
I suggest you take the advice of your mechanic----you do trust him / her?????
having problem with 9.9 1974 e
having problem with 9.9 1974 evinrude putting clutch dog and shifting yoke back in lower unit i would appricate any help thanks
