Neil Mitchell
I have a 2012 Mercury 4 stroke, 60HP non bigfoot. I have had a couple of small issues with the EFI so decided to buy a Rinda Technologies Techmate scantool-standard. PT # 94040 with the latest ver 6 software. While this may seem like an over kill, I live in a very isolated place 2500 miles south of Hawaii. Mercury service centers are 2000 miles away in NZ. I am an old school mechanic and have worked on and repaired all manor of marine engines for over 45 years.
My engine runs fine for the most part but occasionally will run hot with limiting revs being the result. 400 hours service. Well maintained.
I used my new scan tool today for the first time. While it seemed to run through most of it's menus and options without bother, (during bootup for want of better words), it would not go further than "smartcraft PCM" as it would not communicate or identify with my motors ECM, telling me to check the cable connections. This I have obviously done a number of times. I can therefore not check any engine data stored or anything for that matter. The scan tool is connected to the wiring loom via a 4 wire plug which came with the scan tool. I have followed all instructions in the users guide and outboard engine supplement provided to the letter but this scan tool just refuses to talk to my ECM. I note that my ECM has a part number of 8M0059789. I also note that the manuel says the scan tool will "attempt" to comunicate.
My question: Is my new scan tool compatible with this ECM?
My ECM looks identical in shape to a Merc ECM-555, although mine does have a slightly different plug.
Any suggestions re scan tool?
Thank you.
Thank you.
