"I am not sure what went wrong
"I am not sure what went wrong. The story is: the motor was running pretty good. Occasional stall at low rpms, some times ti would take a few seconds longer to rev down after running at higher speeds but nothing majorly wrong. Against my wife’s opinion(don’t fix what isn’t broken) I decided to put in Boyesen Power reeds to see if I could get a bit more out of the motor. This is where it gets iffy. Before I took the motor apart to do the reeds I ran the Evinrude de-carb engine tuner through it. Having rebuilt the motor myself two years ago I figured I would have the new reeds swaped in quick, and the decarb could do its work in the mean time. Unfortunately I got the motor apart and realized that it had 6 peddle reeds and the ones I had received were 5 peddle. So it took 5 Days to get the new reeds in and all the while the decarb was sitting in the motor. Not sure if that caused anything but just letting you know the whole story. After getting the reeds in I took it to a local shop for a Link and Sync. They ran it for 20 min then said it lost spark and I needed a CDI box, bad luck I guess. Once they put a new one on and had spark, they said that I had an air leak and they wanted to take off the carbs and intake to make sure that I didn’t make a mistake. Also they said that the recirculation hoses were routed wrong and changed them. Which I am not sure of because it ran for two plus years the way they were. After redoing all the gaskets and checking the reeds they said that they still had a lean condition in #3 cylinder. They tried swapping carbs around and still a lean condition on #3. At this point they said that it must be and internal air leak because they tried spraying carb cleaner everywhere to see if they could find a leak around the block or anywhere. I ended up picking up the boat and it was coughing and sneezing badly. I took it over to another mechanic friend of mine who sat there with it in the lake and adjusted the carbs and timing and got it to calm right down. It was purring like a kitten at idle and ran great up and down the lake three times. The next day I ran it on a long trip and after about 30 minutes at 4000 rpm it suddenly lost all power. I took the motor apart and the top left piston when standing behind the boat is trashed. I think its #2 if I am not mistaken. I just cant figure out how replacing the reeds can all of a sudden cause all these issues. And I am not sure how to figure out what caused it. Sorry for the long story but I am at a loss. Any thoughts would be greatly appreciated."
