Hellow I'm having trouble
Hellow I'm having trouble with stb. motor timing. Distributer was relpaced before I got the boat it spins clock wise like #1 motor . Is this normal and does it change fireing order. I changed exuast manifolds and when I was done started engine had backfireing out of carb it became more often and less when adjusting timing but could not get close to mark without stalling so I tryed to advance one grove whent wrong way got worse so tryed tdc with #1 cylinder got it running pretty good barely backfiring but not near flywheel mark so tried to move one grove got worse wrong way maybee. But then I noticede I crused lower carb gasket when lying on carb replacing exaust manifold replaced that started on tdc again couldn't get to fire. Do I have the right sequence with 1 2 ...etc. or is it 1 8 ...etc because of clock wise distributor? any ideas? Then all the suden it won't turn over no power to motor from either key on stb. motor is there a reset or fuse?
