dansera
"Hi,
I have found that the sm
"Hi,
I have found that the small spring, located on the side of the reversing pawl mechanism of my VP 290 leg,is broken. This is the spring located beneath one of the two 12mm nuts holding the major pin in place and NOT one of the two identical tension springs found on both sides of the mechanism. This spring must have been broken for a number of years, yet I never had any problems with the leg kicking up when in reverse gear.
My question is: how important is this spring for the proper function of the reversing pawl especially as it is not one of the three major springs in the pawl assembly? Also what is the function of the bracket onto which this spring is located? Finally where can I get a replacement for this spring?
Thanks,
Lawrence."
"Hi,
Thanks,
Lawrence."
