I committed the ultimately sin and accidentally reversed the cables on one of my pair of batteries. When I tried to start, it fried the other battery. I was able to start the engine on the one good battery, but had insufficient power under load. I could only get up to about 3800 rpm which was not enough to get on plane. Back at the house, I replaced the bad battery, checked that the other battery was still able to hold a charge, replaced the ground wire connecting the two, and replaced a 30 amp inline fuse (it looked fine but I replace it anyway). The engine runs fine on the muffs, but on the water I have the same problem--maxing out at 3800 rpm and insufficient power to plane. Given that the current from the improperly connected battery seemed to go to the second battery, what else could I have damaged that would cause this problem (e.g., power pack, stator, etc.)? The engine had recently been serviced and was running fine, so I am assuming it is not a separate (e.g., fuel) problem. I have a 1988 Johnson 120 outboard. Thanks for any leads.
