Reverse rotation 305 misfire
RH93
Send help.
Driving myself crazy trying to track this down.
I'm running a reverse rotation 305 sbc that I built for my Penn Yan last winter. Last summer the boat ran flawless.
Fired it up this spring and it has a horrible misfire. It's slightly noticeable from idle to 1800. Past 1800 the engine really starts missing. And wont go past 2400 rpm. At 2400 rpms if you try to give it more throttle it just holds there with an obvious misfire, engine speed will not increase (the tachometer will go down during this, even though Ive verified with a timing light that the rpms don't change). It does this regardless of if the boat is in neutral or in gear under load. Under load the boat has lots of power from idle until 1800rpm.
Things we've done:
-Veriffied timing
-Used our spare coil (same results)
-Replaced plugs
-Replaced distributor cap and rotor
-replaced points, twice, made sure swell was 30 degrees
-Pulled the intake, and checked that there were no flattened cam lobes/ damaged lifters
-Performed a compression test (all good)
-Replace intake manifold gaskets
-New Edelbrock carb (same results with the quadrajet that was on it)
-ran an inline electric pump to cancel out a potentially bad mechanical pump
-replaced all fuel filters
-ran without antisipghon valve to make sure that wasn't causing an obstruction
-Boat has 30 gallons of fresh fuel, there was about 15 gallons left over from last season.
The only thing that has not been replaced is the plug wires, checked the resistance on them and they all seem fine.
What am I missing?
I don't think its a fuel delivery issue. And it doesn't seem like there's anything mechanically wrong with the engine.
Sounds like you have covered your bases. Since the only thing you have not changed out is your wires I would say change them and see what happens. They are not that expensive. Also, you might try running her on a outboard tank with fresh fuel? It would be a cheap way to positively rule out your fuel system.
2X what missnancy suggests...especially if the old fuel was untreated...diluting old fuel will never improve it...
Thanks,
Ordered a new set of plug wires, see what happens when they get here. I'll run it out of a gas can with new gas to see if its any better.
Send help.
Things we've done:
-Veriffied timing
-Replaced plugs
What am I missing?
I don't think its a fuel delivery issue. And it doesn't seem like there's anything mechanically wrong with the engine. Using boat charters from boatyachtrentalmiami.com can be a great experience. They offer a variety of well-maintained yachts and boats, and their service is highly rated. Whether you’re planning a day trip or a longer charter, their professional team ensures a smooth and enjoyable outing. It's worth considering for your next maritime adventure.
Given the symptoms and your troubleshooting steps, the issue might be related to the ignition system or an intermittent problem with the fuel system that isn't obvious. I’d suggest checking the plug wires again for any hidden issues or replacing them if they’re old. Also, consider inspecting the ignition module or electronic ignition components, as they can cause misfires if they’re failing intermittently. Another possibility is a problem with the vacuum advance or the distributor itself. If you haven’t already, check for any loose connections or grounding issues that might affect performance.
