Reverse Gear Slippage 2006 6.1 L
Formula Owner
I have a Mercruiser 6.1 Horizon Bravo 3 drive ( 2006 ). I recently had removed the lower unit to check gimble bearing because I thought I heard a noise coming from the back of the engine during fresh water flush. they inspected it and no problems. Just this weekend my reverse started to delay until I would give it a little more gas and then sometimes a small bang into gear. My forward gear works smooth.
Could this have anything to do with my service checking the gimble bearing?
Re: Reverse Gear Slippage
Most likely a cable adjustment. That bravo needs a special alignment tool (plastic) to set the cable at the shift bracket.
I would start there.
They could have put it in forward gear (which is neccesary for alpha's) and stretch the cable or it could just be cooinsendence.....
forward is good you say . Wait to the end of the season then go after the problem.
Damn your too far away or i would tell you to bring it to BT Doctur , then i would come over also to his place. I don't charge but he does.
So my marina has told me that is was the clutch cone assembly and that I needed to replace it. They said it was not cracked just worn.
What is the life span on these. I have haf two other Formulas with Mercruiser engines for 12 - 13 years each and never came upon this. This boat is shy of 5 years. I saw articles on the correct gear lube and I always use the right quicksilver lube and make sure the reserve bottle is at full level. Any insight would be helpful.
It sounds unlikely that a 4 year old boat would need a cone clutch assembly.
How many hours on on it?
If it is in excess of 500 -800 then maybe...........And I say MAYBE!!
Also you need to ask if the cone clutch assembly in your outdrive is the current rev.
If it is not this will cost in excess of $1500 for parts alone......the latest rev forces the entire assembly to be replaced.
The dealer will have that info based on the outdrive serial number.
Last year I did a 1987 bravo one and there was no replacement of just the worn parts, Needed to replaced everything....................
Also make sure the link arm that goes thru the upper housing ( forward to aft) is in PERFECT shape as this will also greatly influence the shifting!!
If the pivot points are worn or corroded it will make shifting tough.
