Reusing piston rings
renegade
"took apart my 175HP V6 1980 e
"took apart my 175HP V6 1980 evinrude, couple of the piston rings were stuck in the piston. after cleaning they gapped fine. i went ahead and hone the cylinders. can i reused the rings?"
"Its always best to use new pa
"Its always best to use new parts..How-ever, if thr ring gap is with-in factory specs, and there is no up-and-down movement of the rings in the ring gaps, should be ok fow awhile..."
"If cylinders have been honed/
"If cylinders have been honed/de-glazed, change the rings. One thing is the ring gap, but more important the spring tension of the rings. A cheap replacement compared to the cost allready invested in the engine!"
