roger40033
Hello to all from Kentucky. My name is roger and I hope I am putting this in the right area but here goes nothing. I recently traded an old van I had for a 1986 procraft bassboat. It has a mercury 1150 outboard on it. I took it out for a test run last week and decided to change the impeller assembly because I didn't like the tell tale stream it was producing. I also noticed that it has a tachometer, trim indicator gauge and a new water pressure gauge but none works. when I looked behind the gauges I noticed that the wires were cut for the tach but the other gauges have wires attached. I cross referenced the motor serial which was 4737646 which turns out to be a 1977 motor. does this motor have the capabilities to attach the gauges up to and if so where would the connections could be. Thanks for the opportunity to ask my question
