I cooked two alternators this weekend. One because I bridged across two terminals while trying to test output with a multimeter and the second one because I reversed the ground and battery lead on the old Paris Rhone.
So, I'm going to get another alternator as soon as I can, either a Delco 10si or a Delco 3 wire and try again. (I will have the new alternator tested today just in case it still works)
Now to my question: I pulled the resistor wire from the exciter lead to test it with my multimeter. I put the probes on either end of the wire with the resistor in the middle on my workbench and set it to read ohms. The needle moved over to the zero on the right hand side.
Is that what it should read? Speak slowly please, I'm an electrical idiot.
