Resetting IAC on 50 Mercruiser
dustin_22
I am have trouble starting my
I am have trouble starting my engine after reaching operating temp and idles high at times.
It is a MPI engine so it should be easy starting.
I was trying to find out if there is any way
to reset the IAC or is something that
would have to be replaced?
"You should maybe get a Merc d
"You should maybe get a Merc dealer to run a diagnostic and see what comes up. If it's the IAC (which sounds likely given your symptoms), then you know you are changing the right thing rather than guessing.
It sounds like it may be sticking.
Rod"
"The IAC resets every time the
"The IAC resets every time the start cycle is initiated, there is no manual reset or adjustment. Take a good look-see at the throttle body. Just like a carb, they can come loose and create an air leak. Make sure your linkage is working properly as well. If everything looks normal, take Rod's advice, a quick check with the right tool will pinpoint the problem and save you from changing unnecessary, and often expensive, parts."
