"Now that I've figured out
"Now that I've figured out that the engine is indeed bad, I would like your imput on the next step. The current engine is a 1990 with mechanical fuel pump, if I buy a new engine should I upgrade to the electronic fuel pump version with the balance shaft or will there be issues bolting up all of the periferals? Is there any advantage with the newer version, electronic fuel pump or balance shaft? Or should I just play it safe and keep to the original style? The pricing is virtually the same. I will be keeping my 2 barrel carb (I like the fuel economy). Any suggestions appreciated. Thanks again."
