seaduction
"hi just replaced water pump o
"hi just replaced water pump on out drive. installed gear housing everything worked fine. so i thought..... it would not go into forward or reverse. i read the man. and then noticed that it says to lock into foward gear, and also to shift it into foward gear. ive done both had the unit off 3 different times. but still cant get it to work properly. what am i doing wrong. and is there a way to adjust the shifting without taking the gear housing off again?"
