"I have 1991 crusaders 454 fre
"I have 1991 crusaders 454 fresh water cooled engines. I am replacing the ucoolers.
I'm not too sure which ones to order as when I searched the web and made a couple calls I found that a few different changes all around those years.
Best to remove the old ones first and find the cru# on the unit, and be able to bring it to a local supplier if need be.
I don’t see the remove/install instructions in the shop manual.
Is there a way to do this without a mess and without changing the engine and tranny oils?
Thinking to cap the oil connections if I knew the NPT and dia ahead of time. I changed engine oil 1-2 hours before I winterized. Anyone? Al?
PS I have borg warner velvet drive transmission. Does anyone change the tranny filter when you suck the AFT out? I was told not to years ago when I had a boat mechanic. “might be looking for trouble” if I recall.
Thanks,
Scott"
Thanks,
Scott"
