Jimmie Richards
Quick question. I replaced the impeller myself about 4 years ago and ran into some trouble. The instructions I had said to place throttle in frwd before removing lower unit. Which I did. I replaced everything and put the lower unit back on. When I hit the water, frwd ended up going in reverse. I was baffled and had to take to a mechanic to fix.
Question: is it necessary to put throttle in frwd? If so, what did i do wrong to cause things being reversed?
Thanks as I am going to give this a try one more time.
jime
jime
