Replacing head gasket
maurod
I am replacing a head gasket f
I am replacing a head gasket for a 85 hp force and the manual says to use RTV sealant. The RTV sealant says not for head gaskets. What should I do??
"If you are just replacing the
"If you are just replacing the head gasket, don't use any rtv at all, just torque the new gasket in to specs. If you allready seperated the head and the head cover then use rtv between those 2. Most likely, you did not seperate the cover from the head."
