Good day to all.
I am a newbie to the forum .I have a 26 FT hourston glascraft with a volvo aq 260 and origanally came with a 280 sp.outdrive I've receintly changed the lower out to a duo prop WOW what a difference that made.
My question is that i am slowly piecing together a 290 outdrive I have the newer style transom with the larger pins that attach to the suspension fork,but the leg that i have is a DP A that has the smaller diameter hole on the suspension fork .Is it possible to change the suspension fork to the newer style on the DP A
Question#2 I am also thinking about getting a new crate motor a 330 HP Vortec long block. I know that I will need a new intake manifold Iam going to stay with carb. New starter new flywheel and possible a new cam. Will my egsisting bellhousing bolt up to the larger flywheel. If there is anything else that i need to chage over any input would be greatly appreciated
Thank You in advance Cheers
