timmy66commander
Hello,
I have a 1988 Model 270/5.7L motor that has low compression in a few cylinders. The motor had a new head gasket and heads shaved/rebuilt approx 7 yrs ago. Unknown hours since then, but at least 5000 miles (nautical miles/GPS). The block is a rebuild from "Recon/Philly"). It does use a bit of oil (1 qt/400 miles??).
Compression is as follows;
1/170 lbs
3/135 lbs
5/170 lbs
7/165 lbs
2/170 lbs
4/70 lbs
6/145 lbs
8/135 lbs
My question is, replace with long block or redo the heads/gasket again?
Thx,
Timmy
1/170 lbs
3/135 lbs
5/170 lbs
7/165 lbs
2/170 lbs
4/70 lbs
6/145 lbs
8/135 lbs
Thx,
Timmy
